Looking for suggestions on FLV converter software for a client of ours. He is required to convert dozens of video per week and sometimes per day. We set him up with Sorenson Squeeze 4.5 several months ago and spent plenty of (wasted) time adjusting settings for him. Now he's flipped out and refuses to go on with Squeeze because he claims it's difficult to work with
Anyway, He's on Vista and his ability to correctly use a computer is very poor and this is the guy in charge of a user-submitted video site we custom built for him. I have done some limited browsing for a replacement program, but have not had much luck other than Flix Pro. He also would like the ability to select crop ranges and preview the video right in the program. Sounds to me he liked Squeeze just fine. Ugh.
If anyone has suggestions on some software or need me to answer any more specific questions, please let me know.
	Can you clarify if you meant convert to FLV or from FLV?
 What are your desired input and output formats/containers/codecs ?
 When you say "select crop ranges" do you mean trim (as in cutting temporal segments) or crop (as in removing edges)?
	That would be for converting TO FLV from various formats including AVI and WMV.
 Output specs currently used in Squeeze are....
 Spark Pro
 2-Pass VBR
 768Kbps
 450x338
 30 fps
 Audio
 MP3
 48Kbps
 22050 Stereo
 Crop range as in trimming, yes. Not removing edges.
	@hech54 - I don't think Riva has visual editing for trimming or batch capabilities?
 Personally I would use avidemux for this, because it supports many formats, has visual editing, batch capabilities and best of all free. Unfortunately it takes a bit to get used to
 It sounds like your client is not very computer saavy so you are looking for something "idiot proof." I've used Squeeze 5 and Flix Pro, both are not that difficult to use !
 Sorry I have no better ideas - I hope others have easier to use / better suggestions
  Is it recommended to convert or it leave it at their original flv format?By leandro in forum Newbie / General discussionsReplies: 9Last Post: 6th Dec 2011, 12:59
  Need a recommended FLV to AVI converterBy OM2 in forum Newbie / General discussionsReplies: 19Last Post: 20th Sep 2009, 00:30
  FLV to Avi or MPG, recommended settings?By dzoni in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 16:27
  What's the best FLV converter + best method to create FLV's from pure videoBy OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 20:23
  The sewell VGA-to-TV converter. Recommended to all!By Super Warrior in forum ComputerReplies: 2Last Post: 8th Dec 2007, 15:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
