I have a problem, i have quite a few old tapes, i.e. over 10 years old. they where taped on an old Panasonic Mono VCR, i want to copy these to DivX files and store them on CD. I have the capture card working, but on some of my tapes, i get a problem where the frames seem to shift. That is if a person is at one position in the frame and then moves to another position, the frames will switch rapidly between the two positions over a number of frames.
As you can imagine, this is very irritating, could i have a problem with low signal strength?, i have a video enhancer attached between the vcr and the card but this makes no difference.It happens on half of my tapes. I also have 6 -7 Young ones episodes, 3 taped OK the other 3 have the frame shifting problem. Could it be a problem with the frame rate? The tapes are PAL and i am capturing at 25 fps.
Thanks.
have you checked what your actual output frame rate is? if i undertand your question that might be the problem... Have you made sure you turned of all unnecessary software before caputring (check by doing ctrl alt del)
I have not checked the frame rate comming from the video? Is there a utility to do this. I am assuming that when the video degrades, the frame rate from the video may reduce?
maybe the A/D converter get's out of sync.The capture will see only the last good frame overlayed with parts of the actual frame.
I get something similar (I think) when I record of old tapes. There are two problems actually - 1. a frame will get left shifted about 20%, and 2. There is a burst of multi-colour' in a frame. It happens infrequently, and there are generally not 'bunches' of errors together.
I have put it down to deteriation of the video signal (as I got a lot of it after I left one of my very precious tapes next to my monitor for a few days - and many degausses - and it now exhibits a LOT of these problems.)
It would be really good if someone has a solution though (for the more genearl case).
For now, I have been masking the offending frames (where there are only a few spread thourhg out a video) in virtualdub, which it quite unnoticable in the finished product. -
I'm using the Hollywood Bridge for capturing.I'm told by Dazzle, that you can't do anything about bad frames.I wrote a small program fro detecting bad frames( through the audio part: always no audio or distortred audio) and cutting (through ULEAD video editor).
The older the tape, the more errors you get.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 16:14 -
Neither Vegas Video nor WinDV show dropped frames count after capture
By korey99 in forum Capturing and VCRReplies: 13Last Post: 9th Apr 2009, 16:25 -
Irregular TV program durations - an effort to defeat DVRs?
By ebenton in forum DVB / IPTVReplies: 2Last Post: 13th Feb 2009, 20:30 -
How can I automatically capture still frames of a video?
By SamScaff in forum Capturing and VCRReplies: 1Last Post: 13th Sep 2007, 19:28
