Hi everybody....
I tried convert MPEG two channel audio(left & right channel) to RMVB. But can't play with two channel audio. I used any converter like xilisoft, apex, avs can't too.
How i can know this RMVB file is two channel audio or one channel audio?
What's converter/tools can convert VCD.DAT/MPEG two channel audio to RMVB two channel audio.
thx
newbievideohelp
Results 1 to 16 of 16
You can use mediainfo to verify if audio is two channels
Easy RealMedia Producer (free) should be able to convert to .rmvb -
i tried convert with Easy RealMedia ProducerV1.94 but i can't play this rmvb file with 2 channel too. i checked this rmvb file with MediaInfo.
From Media Info i got this rmvb file is 2 channel too.
please any one can help me
thx -
Please any one can help me......
Please any one can help me...... -
For playback, install Real Alternative and use MPC or use SMPlayerOriginally Posted by newbievideohelp
Hi... Thx for your response.
my comp intalled Real Alternative with Media Player Classic. But it can't played with 2 channel too. so until now i don't know. how to played rmvb file with 2 channel.
thx -
Please describe the problem more:
does it play at all?
do you even hear 1 channel? (mono)
do you see video at all?
do other file types (e.g. .mpg, .avi) play normally?
did you try smplayer?
exactly what is the problem?
Try playing this clip back (it's <1mb .rmvb); does it play ok on your system?
ironman.rmvb -
thx poisondeathray for your reply.
i can play all this rmvb file. at media player classic i change to left channel or to right channel but the sound not different. but before i convert to rvmb this file have left right channel different sound.
i had try play with other type video file but it can play with 2 channel different sound.
I try ironman.rmvb play with smplayer it only 1 channel. i tried other file rmvb it also show one channel. but this file i check with mediaInfo it show 2 channel.
what problem?
thx. -
I'm not sure if I understand you...2 channel is stereo
If the source input L and R channels are different, the .rmvb will be different
If they are the same, the output L and R channels for the .rmvb will be the same -
poisondeathray - I think the original poster is trying to describe a typical Asian VCD with different languages in each channel. For example, Cantonese on the left and Mandarin on the right.
Almost nobody here converts to RM because it's a pretty bad and almost useless codec for most of us. I have no idea why your conversion isn't working correctly. Maybe there is a forum on the Real website where you can ask for help. -
thx poisondeathray,
yes you right. if the L & R channel same the sound will be same. But i can try the L/R sound like DVD file i can use dvd2avi so i can separate to L & R channel.
can you help me how to sepate my rmvb file.
thx jman98
yes mean like youi say. i tried convert to rmvb but now i don't know what are the L R channel sound is same or not. Thx for your information. I'll try to real forem. thx -
I tried find on web about how to convert to rmvb file with 2 channel audio. but can't find information about it. Have someone know about it or know where i can find this information.
Help me please.................
Help me please................. -
I think you really need to read again where I said this:Originally Posted by newbievideohelp
If we had any idea how to help you, I think you would have gotten help already.Originally Posted by jman98 -
Tried this one:
http://www.aone-soft.com/mp4_video_converter.htm
I usually go the other way around, from RMVB to Xvid or Mpeg. If you're looking at a net posting, Xvid/Divx is a better way to go than Real Media which might be good for streaming media over the web or playback on a handheld device but playback on a TV is terrible, way below what I would normally watch....
Also, I have no idea if this will allow you to retain the two separate audio streams which I suspect is what you want to do. Most stuff I have seen with RMVB downloads were foreign films with one audio track and one subtitle track. Those can be played back easily. There was a reason that your video was in the format it was....so you could have the 2 channels of audio selectable. I think you may have to go and see if RMVB will allow you to have 2 selectable audio streams BEFORE you start encoding anything. The format may not support it....
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 18:06 -
Removing audio channel from dat file
By Lextar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 25th Jul 2010, 23:08 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47 -
How to switch downloaded avi/rmvb audio channel?
By Dewprismzz in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2007, 15:55
