I'm trying to rip individual cartoon episodes from a disc using AutoGK but each time I try it encodes the whole disc even after choosing an individual PGC. I load AGK, choose the main IFO for the VOB set and gives me a chose of all the segments available. With any one I choose it does the same thing. Is there a way to rip each individually?
Results 1 to 9 of 9
During decrypting use DVD Decrypter set for IFO Mode (at the top, Mode->IFO). Decrypt each cartoon to its own folder on the hard drive and then run each through AutoGK.Is there a way to rip each individually?
Try PGCDemux or open the Video_TS folder in DVD Shrink and use Re-Author mode to get just the episode you want.
Read my blog here.
You can use the re-author function in DVD Shrink to back up the episodes individually before using AutoGK. You need to open the edit tool in re-author mode. It's a trick I use quite often to maintain sync on individual episodes encoded with VBR audio.Originally Posted by stantheman1976
EDIT: Sorry, didn't spot Gunslingers reply earlier. -
Thanks for the advice guys. Getting a weird problem now. When I rip the episodes they aren't playing full screen. There is a black border around all 4 sides. The disc plays full screen as it should.
how many MB equal GB/ how many episodes can i fit on disc?
By janeydoll in forum Video ConversionReplies: 6Last Post: 21st Oct 2010, 10:20 -
Ripping Single Episodes of Cartoons for Re-Authoring - Jaggies
By jdmba in forum DVD RippingReplies: 7Last Post: 5th Aug 2009, 14:19 -
AutoGK Filesize in Single Pass Mode
By Arlo in forum DVD RippingReplies: 3Last Post: 7th Jan 2009, 17:21 -
only 3 episodes of 6 will decrypt of futurama vol. 3 disc 1
By norm83 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2008, 19:20 -
Easiest way to convert episodes from a dvd to single episode files?
By Pj10 in forum Newbie / General discussionsReplies: 6Last Post: 21st Dec 2007, 22:42
