I did a video/dvd for my wife's birthday. I used my jvc mini dv camcorder to record different video clips from people, then I placed it on windows movie maker and made a dvd. I used converxtodvd to make it playable on all dvd players (as I had to give it to all her brothers). THe problem is that when I watched it on the dvd player, it played back the video clips that I did with my camcorder kind of grainy/blurry. I mean you can still see it fine but it is NO WHERE near as clear as it is when I watch it on playback mode directly on my mini dv camcorder. I am assuming that the converxtodvd caused a big degradation. What other software could I have used so that the final dvd is more clear?
James
How did you export from Movie Maker? WMV or DV-AVI?
Use DV-AVI.
What bit rate did you use in converxtodvd to encode MPeg2?
For camcorder material, max the bit rate (e.g. 8 to 9.5 Mb/s CBR or VBR average ).
Don't deinterlace.
How much are you willing to spend?
The better consumer programs are
Adobe Premiere Elements
Sony Vegas Movie Studio
ULead Video Studio (emphasis on editing)
ULead Movie Factory (emphasis on menu authoring options)
The "best" options can only be addressed in the context of a budget.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
How to cut out clips from DVDs and convert to AVI, MP4 using free software
By Baldrick in forum User guidesReplies: 13Last Post: 13th Dec 2016, 20:33 -
Database software to manage my movie clips
By stallion2008 in forum Newbie / General discussionsReplies: 45Last Post: 22nd Feb 2013, 10:32 -
Software for extracting clips from DVD
By gaurav200x in forum EditingReplies: 2Last Post: 10th Aug 2010, 14:43 -
TMPGEnc convert multiple clips with 29.97 & 25 fps to a dvd
By sychern in forum Video ConversionReplies: 2Last Post: 11th Oct 2008, 16:34 -
software to join video clips
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 04:38
