Should I even be attempting to do any type of wireless networking with Windows 2000? I mean I can sometimes get it to work, but I have to turn on services that I naever had running before, and I'm not finding a lot of instructions on the internet. Even the default setting for the LAN when I added it was missing a protocal. I only found the lissing protocal when I compard it to a XP machine wireless setup.
Results 1 to 12 of 12
I never had a problem with it on my old laptop until the PMC/CIA adapter died. I don't recall ever having to do anything special to make it work past the one-time, initial setup. I know that I did NOT install any extra software, either from my ISP or that came with the router.
Buy My Books -
Originally Posted by zzyzzx
You should get an installer with the hardware (PCMCIA card, USB dongle, etc) that gives you all the drivers and a client.
If your machine is not really mobile, the XP Wifi Zero Config is quite convenient, but there are also several nice third-party clients available. I prefer Boingo as a laptop connection manager, and use it on my XP ThinkPad.
Are you trying to run your PC as an access point, or using a wifi router? Perhaps that's more complex, never tried it myself. -
I am getting this error when I try to run the Windows 2000 service for Wireless configuration:
Unfortunately, except for the "Wireless configuration" text, the rest of the error message is generic. So when I search for the error code, I'm getting other unrelated stuff. -
And you might try these forums:
http://www.wifi-forum.com/wf/
http://www.wirelessforums.org/
http://wireless.wikia.com/wiki/Contents -
Use the manufacturer's software and you should be okay. -
I did have SP4 on my old laptop. I wish I still had it so I could help you get yours set up, but at this point I'm working from memory, and it ain't what it used to be...
Buy My Books -
I'm running a wireless d-link pci card with windows 2000 sp4 on one of my computers at home with no issues. Probably as suggested above is go with the manufacturers software. let us know of your progress.
-PB -
I did finally get it to work with MS software. I had to add the protocal Client for Miscorsoft Networks to the LAN adapter and then I could get it to work. I probably won't use it again, becasue the manufacturer's software is better though.
Windows 7 networking with Linux
By kenmo in forum ComputerReplies: 25Last Post: 25th Jun 2012, 16:43 -
Linux and Windows 7 networking?
By kenmo in forum LinuxReplies: 2Last Post: 29th Nov 2009, 20:34 -
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 25th Mar 2009, 23:18 -
Networking for a moron -- wired and wireless.
By Xylob the Destroyer in forum ComputerReplies: 2Last Post: 23rd May 2008, 12:47 -
Windows 2000 question.
By AlecWest in forum ComputerReplies: 34Last Post: 1st Jun 2007, 17:54
