Hi,
I need a good & easy to use DVD Cutter/joiner soft. There are some cutter in net, but not free or can cut for 5/10 mins only. So, please give me some reference.
~r
If you want frame accuracy with minimal to no re-encoding them you have to pay. If you can live with I frame accuracy then there are many more options, including cuttermaran and mpeg2cut2.
Look in the tools section for moreRead my blog here.
Hi guns1,
I've searched tools section, but not any suitable soft listed there.
Let's try with ur list. And can u explaine about "I frame"?
~r -
Cuttermaran can do frame-accurate cutting, with a small amount of re-encoding around the cuts. Otherwise, it can begin cuts on I-frames and end them on P-frames with no re-encoding.
I-frames appear at the start of every group of pictures (GOP). For me, every 15 frames. Look at the glossary for more information. (That link is located on the left side of VideoHelp webpages near the top.) -
Cuttermaran can only open separate video and audio streams. Demultiplex the video and audio from a dvd using for example pgcdemux.
Looking for AVI cutter
By rocks911 in forum EditingReplies: 2Last Post: 27th Jan 2012, 17:23 -
VCD Cutter
By devilcoelhodog in forum EditingReplies: 0Last Post: 16th Jan 2010, 16:39 -
h.264 ts cutter
By stewart041170 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2010, 16:06 -
Good DVD Cutter and converter
By mayflower in forum Video ConversionReplies: 2Last Post: 6th Oct 2009, 20:35
