Everytime I change my "View" to a certain one (thumbnails, tiles, icon, list, details) and I exit the folder, it changes back to thumbnails for some reason. I want it to stay on the last type I leave it to (list), but automatically changes back to "thumbnails" when I exit and re-renter the folder. How do I make it stay according to the last one I leave it as?
Set the view to the way you want it to be.
Click on Tools -> Folder Options
Click on the View tab
Scroll down the Advanced Settings list and make sure Remember Each Folders View Settings is ticked. If not, tick it and click OK.
Remember that this only holds for Windows Explorer. It doesn't hold for things like the File->Open dialogue etc.
If you want this view to carry across all your folders, click the Apply to All Folders button, then click OK.Read my blog here.
Yep, I go to the Advanced Settings list and "Remember Each Folders View" setting is ticked. It is already checked.
But when I leave the folder, it changes one to "Icon" even after I change it to "List". The other one it changes to "Thumbnail" after I change it to "List".
It just won't remember it for some reason. -
I have seen this recommended. No guarantees, and you do this at your own risk.
XP has a limit to the number of views it can remember. This registry change will increase that limit from 400 to 8000 : http://www.kellys-korner-xp.com/regs_edits/bags8000.reg
Download the .reg file, double-click on it and let it do it's thing. Once it is done, reboot.
Open Windows Explorer, then click on Tools -> Folder Options, then the View tab. Click Reset All Folders, then click OK. Close Windows Explorer.
Open Windows Explorer, then click on Tools -> Folder Options, then the View tab. Set your folder views to be as you want them, and see if they stick.Read my blog here.
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
How do you change the default View Setting for a folder's contents in Windo
By videopoo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Feb 2009, 17:41 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 00:01
