Anyone seen that before?
Index of Scan Line is out of range (360)
I was encoding an AVI file to MPEG2...
Loaded the normal SVCD (NTSC) template for TMPGEnc.
Changed to CQ_VBR (50), encode mode = non-interlace,
motion estimate search (fast).
The frame rate of the avi is 23.976, but when I encoded with NTSC Film it had no audio. I saw someone else had the same problem so they used NTSC instead. I did the same and got this.
I had this problem a while ago with a PAL captured AVI. To get rid of it go to settings -> advanced -> source range, and skip the first couple of frames. Something in the first frame might be buggered, anyway this fixed it with mine.
Cheers,
Bolix
How To Capture Xbox 360 Content Without Line Distortion
By SLOANEY in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2012, 10:26 -
multiAVCHD - (RT) Invalid array index. Array is empty - Line 109.
By JackyWang in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Oct 2011, 08:53 -
Index Out of Range
By bessen69 in forum DVD RippingReplies: 6Last Post: 25th May 2010, 08:34 -
Help encoding 360 x 360 videos (spherical movies)
By sapojow in forum Video Streaming DownloadingReplies: 29Last Post: 1st Aug 2009, 19:23 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06
