Not sure if there's a program that automates this, and if there was, it's probably not 100% effective. If there is one, please point me in the right direction.
I'll most likely have to manually do this. What program (or way) can I quickly add mutes to the audio? Or maybe something less "harsh" like a dip in the volume.
Thanks.
				Results 1 to 9 of 9
	What format is your source audio in?
 Manually, you can use Audacity to do this if the source is WAV or MP3 (or a couple others that I can't remember right now, but not AC3)."Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
	If this is for a commentary track or voice over, there is a filter called Auto Duck that uses one audio track to control the volume on another.
 https://forum.videohelp.com/topic304728.html#1870815
 However as you have provided no context for your request - on what basis are you muting or reducing the volume ? - I don't know if this is what you are after.Read my blog here.
	I know I was going to have to manually do this, but what program can make it easier for me? Adding, like, half-second mutes very quick.
	In Audacity you select the section you want to block out and then Edit/Silence. This silences out the section but keeps the file the same length so if you remux it with video it will still be in sync. "Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
  Would there be a way to smooth out audio dips in a vhs capture?By yoda313 in forum AudioReplies: 27Last Post: 10th Jan 2011, 17:46
  Editing volume levels without too much video quality loss.By meneedit in forum EditingReplies: 7Last Post: 30th Sep 2010, 06:29
  half way into video it mutesBy jerbear10 in forum MacReplies: 3Last Post: 27th Dec 2009, 22:19
  short film camcoder for video editingBy Smilevil in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 10th Feb 2008, 21:23
  Turning up the Volume after editing a clipBy AndreL in forum EditingReplies: 0Last Post: 11th Jun 2007, 14:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
