My vcd's are very chopy. Could it be I convert it to the wrong fps?does my dvd ony play a certain fps?Do you have to convert it at it to the same as the avi. I tried that and it still plays really chopy.Can any one help.
thanks
we need more info. Open your file with vitualdub and choose file information. Tell us the source file's fps. Also tell us what region you are making the vcd for (NTSC or PAL).
I have the same problem.. I'm covertting an AVI file that has 20.0 fps. for a USA standard VCD. The result is a chopy picture. I tried changing the fps with virtral dub to 23.9 fps but then the picture becomes blocky. I don't know what to do. The vcd almost looks as it's being transmitted via a webcam. But the audio is in sync. I'm convinced that it has to do with the fps of the file because i haven't resulted with any problems like this with any other file with a higher rate.
When you convert 20 fps to 23.976 fps, almost 4 fps will be added. That's not Godsend, but these 4 frames will get duplicated, 4 frames, every second. Of course the result is choppy playback. You should capture at a proper framerate next time.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
