Hi. I buy rare (legit) dvds here in Thailand for resell online. Often, the back of the dvd case will list the disc as being "all-region" without giving any info regarding PAL or NTSC formatting (dvds in both formats are released here on a regular basis). To get to my question, is there a computer program that will read the dvd's format and tell me whether the disc is PAL or NTSC? I realize this is probably a very basic sort of question but I can't seem to find the answer for myself anywhere online. Thanks in advance.
G-Spot or Media Info. Open one of the VOB files. 25 fps is PAL, 23.976 or 29.970 fps is NTSC.
Read my blog here.
You can also put the DVD into the DVD-ROM, open DVDDecrypter, set it for IFO Mode (at the top, Mode->IFO), hit the Stream Processing Tab and it'll tell you.
Are you allowed to use "legit" and "Thailand" and "DVD"in the same sentence?Originally Posted by mcqueen1968
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
