i made a small avi using camstudio. the video has a few MAC/IP address that i dont want displayed in the video. Any software i can use to blot or blur them out of the video?
VirtualDub and a Logo filter would be one choice. One here: http://www.compression.ru/video/logo_removal/index_en.html There are some guides at the bottom of the VD toolpage. You will have to re-encode, though. You can increase the bitrate a little to make up for encoding quality loss but you will gain some filesize.
You may also be able to add a blank subtitle over the numbers to obscure them, and that may be a bit easier than the Logo filter.
EDIT: It looks like Baldrick may have a better method.
[VirtualDub] How to split avi to x parts with one operation?
By ralf07 in forum Video ConversionReplies: 3Last Post: 5th Apr 2012, 17:01 -
Make a playable file from AVI part 5 when you don't have parts 1-4?
By gumbygum in forum Software PlayingReplies: 3Last Post: 12th Aug 2011, 08:51 -
joining two avi parts that overlap?
By nok32 in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2008, 03:40 -
Program to manually split multiple parts of same avi?
By majax79 in forum EditingReplies: 5Last Post: 22nd Dec 2007, 10:49 -
Simple yet good... that can join my 2 parts avi video into 1
By mai_hnf in forum EditingReplies: 6Last Post: 8th Sep 2007, 02:59
