I can be a bit more specific: the AddBorder line appears when you resize.Originally Posted by The Incantation
Results 91 to 120 of 361
'The Incantation', One of the A500 Destroyers
and thisOriginally Posted by blackwalker
just a Up
cause i'm looking around but i didnt find a solution/answer to my questions!
tyvm!! -
Make sure that you have latest drivers installed for Ati 4670.Originally Posted by Vasilis M.
@The Incantation
Addborders are added for compatibility reasons. Blu-Ray standard accepts only 1920x1080 , 1280x720 , 720x576 , 720x480. If you don't like them you can always remove that line manualy and movie will be encoded without those borders. -
Dear Atak_Snajpera, firstly thanks for your answer!
Yes i have the latest drivers on Ati! I need any trick (instal) to enable the fft3dgpu?
Ps. I have Vista Pro with AMD dual 3.2 - mem 2gb - Ati 4670 - Vista codec pack. -
Dear Atak_Snajpera can you check if you have at last
an answer for my previous questions pls
about this one, i look around "A LOT" and i think the answer is "Yes"Originally Posted by blackwalker
at the end i'll have a valid blu-ray structure to burn on a bly-ray disk.
At last i'm 90% sure
about my other questions, i'm still checking on this and other forums.
thx! =) -
ty Atak_Snajpera to confirm it!!Originally Posted by Atak_Snajpera
i'm still having iussue after installinf the new file system (as descibed before)...
i'm not able to read the ext2 format...sigh! -
Install VISTA hehehe
I'm not responsible for UDF driver so why do you ask me?
I have 2 hard disk,1 with xp and 1 with vista, so ints not a problem =)Originally Posted by Atak_Snajpera
Atak_Snajpera, i'm not saying that you are responsible!!!!!
i'm just loojing around if there is a way to have the 2 file system on xp, just this
ty anyway for your GREAT work! -
Hi there,
first of all thanks for this great tutorial, it really helped me a lot. I allready watched my first x264-encoded movie on my popcorn hour!
but now I have a little problem: the file a wanna make should have 2 audio streams. But at RipBot264 I can select just one Audio Stream. How can I achieve that? A similar problem: What do I have to do to make a mkv with 2 subtitles?
Gr33tZ
BaDBoY -
only one audio stream is supported at the moment. You can add multiple subtitles by clicking [...] next to 'subtitles'
well i make my first conversion from bly-ray to a dvd dual layer.
I see perfectly on my computer.
when i try to play with my blu ray player, a samsung BD-P1500, it say that
cannot play the disc!
The blu-ray structure that RipBot264 create is this one:
BDMV
------AUXDATA
------BACKUP
---------------BDJO
---------------CLIPINF (inside the dir i have: 00001.clpi)
---------------PLAYLIST (inside the dir i have: 00000.mpls)
---------------index.bdmv
---------------MovieObject.bdmv
------BDJO
------JAR
------META
------STREAM (inside the dir i have: 00001.m2ts)
CERTIFICATE
------BACKUP
index.bdmv
MovieObject.bdmv
the structure is ok?
if "no", what is wrong with it?
if "yes", maybe my BD Player cannot play it?
ty again for your patience
Updated:
maybe my BD player dont play it because i use a Verbatim "DVD+ dual layer" ad not a "DVD- Dual layer"?
its strange because i played a rental film in DVD+ Layer yesterday and it work fine....
someone can help me?
tyvm!
UPDATED!
maybe i have to set "bitsetting DVD-ROM" to make it compatible!
i'll give it a try!
Can i do it using Imgburn or i have to use Nero? ty! -
in ImgBurn goto Mode-Build and choose the device tab
Now look where you can choose the number of copies (is 1 by default). Right beside to the right are 2 icons...choose the one at most right, the one that looks like a book. Click it and you will be able to change the booktype if your drive supports it.'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
tyvm ron spencer!
found it!
now i'm testing if my samsung BD-1500, using dvd-rom bitsetting,
will play my +dvd dual layer verbatim...
i hope
ty again -
damn...dont work!
when i put the +dvd dual layer (verbatim) looks like the bly ray player (samsung BD-1500) was starting to load it but then it say
"impossible to play it"...
someone have any suggestion on what i can check?
(maybe i'm doing something wrong..)
thx! -
Unfortunately alot of blu ray players do not support blu ray on +R DL. The manufacturers have been really crummy in telling you what they are compatibile with (some will not even play blank blu rays).
For example, my LG BH200, when I updated to the lastest firmware, stopped playing blue ray on +R DL and blank BR discs. So I called them and they said they removed that feature...stupid fools. Like that for alot of players. So I went back to older firmware.
I hate to say this, but I think you are out of luck...call the drive manufacturer and complain for a firmware update (assuming you burned it all ok in ImgBurn, that is, you choose UDF 2.50; but ImbBurn should choose this for you).
If you dragged all the file structure over and proper UDF was chosen, then your player will not play it....this is a hardware issue; again complain is all you can do.
Blu ray is REALLY BAD in this sense....with DVD, all players worked with blanked....crock really'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
ho well, ty for the info.Originally Posted by ron spencer
this really not a good news!
yes i burned with UDF 2.5.
i'll try to call the suport and see what they'll tell me.
what you mean with "blank BR discs"....new unburned BR disc?
if the answer is "Yes", i'll turn back the player to vendor "now" and i'll
change it, cause this is really absurd..!
maybe its better to switch to a PS3? -
Yes! You should really switch to PS3! It plays everything without problems! At the moment it is the best blu-ray player. I have one at home.
[quote="Atak_Snajpera"]
I have Vista 32 bit + 4850 and I have no problems (I had also 1950 = ok) . I have also laptop with Vista 32 bit + x700 and no problems.
yes...I meant with blank Blue Ray discs I meant the ones you can burn on (udf 2.5).
Unfortunately the blu ray world is really a mess for consumers who want to burn their own movies from high def cameras....You really have no idea if a player will support it. Again this was an area where HD DVD was so much better. Sorry, but it is a crap shoot now for burned high def media in a player. If it does not work, send it back. I think most sonys will play such content on burned media.
But you are right...it is absurd....all of HD is absurd right now, which is why it is not selling.'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Thanks to Baldrick for this great guide.
With my humble Quadcore q8200 i completed this guide in roughly 12 hours for a two hour movie. 1920x1080, one to one, no resizing.
1 Pass approx 17 fps
2 Pass approx 6 fps.
Thanks. -
thx Atak_Snajpera
thx ron spencer
i try also using "-DVD single layer" but nothing...!
so its not a Dual Layer pr +/-R problem...its the samsung!! *sigh*
ho well, i think today i'll change it with a PS3
Does the PS3 support also the HD audio tracks?
humm...i'll check around the web!
have a good day!!!!!!! -
got it!
..the PS3!!
and finally i was able to play my "1st" dvd dual layer from blu ray!
what can i say?
video and audio superb!!!
just one thing, too much "black" on all movies, but this is because
i still have a plasma (hitachi 1024x1024 so hd ready) and i play it
at 1080i and not in full hd and the contrast is not so much,
but maybe for christmas i'll buy a new full hd lcd, maybe a samsung series 6 or 7!
ho well, just an answer, i know that there is a program that i can use
to split a ".m2ts".
There is a tool to split files ".ts" ??
ty!
How to easily convert a Blu-ray to MP4/M4V/MKV using free tools
By Baldrick in forum User guidesReplies: 18Last Post: 29th Mar 2018, 03:20 -
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 21:39 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
How to convert blu-ray (m2ts) to mkv or mp4 properly?
By michaellee0101 in forum Video ConversionReplies: 1Last Post: 20th Apr 2011, 08:24
