I am using SDP Multimedia to capture a live video stream, but it shows me duration as only 1 hour (59 min 56 sec to be precise). It continues to record after 1 hour, starting from 0, but writes into a different file, with some cryptic name.
How to force it to do continuous recording ? Or can I concatinate ASF files ? Or should I use some other app (freeware preferable :)) ?
Would appreciate any helpful information.
IF the stream come from FMS 3 With rtmpe protocol So i think you need Replay Media Catcher 3.0.1 . because its only the software available to stream from rtmpe protocol . (not free )
If not so you can use URL Sniffer Software . its free
How to make continuous rotating video with Virtualdub
By frmys in forum EditingReplies: 26Last Post: 19th Aug 2011, 18:24 -
Split recording a continuos live stream
By GordonFreeman in forum Video Streaming DownloadingReplies: 3Last Post: 29th May 2010, 20:09 -
Options for continuous high-speed recording?
By dbooksta in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Apr 2010, 12:36 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 07:14 -
Using DV Camcorder to Stream Live
By johnwenzel in forum Video Streaming DownloadingReplies: 3Last Post: 9th Sep 2009, 06:41
