Results 1 to 9 of 9
    Jan 2008
    Something's wrong with my Windows Media Player. Please explain this:
    ...and tell me what I can do to get the removed options back.
    Jan 2007
    Republic of Texas
    I cannot see anything wrong. The grayed-out stuff at the bottom is the result of you checking Do Not Convert. If you tick the Convert To option, the grayed-out area will come back. Or am I missing what you're trying to say?
    Jan 2008
    I mean, important stuff like parental control, security, DVD, etc. is missing from the options, and I want them back.
  4. Mod Neophyte redwudz's Avatar
    USA
    Although it's rather obvious, if you are trying to back up protected video or audio, WMP won't do it. Personally, I don't use WMP for much of anything. IMO, there are much better players/converters out there. What exactly are you wanting to do?
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Well, normally there are two rows of tabs at the top (at least, it had them when I just checked Tools > Options...); I think that may be what jonghyunchung is asking about.
    jonghyunchung: Does that happen when you check Tools > Options... without a disc in any of your CD/DVD drives? Without a video loaded?
    Jan 2008
    I want to play a DVD, in which it's always being considered a CD Drive, and therefore instead of the disc's name, it just says "Playlist1".
    Jan 2008
    Won't anyone help with what I'm doing wrong with the missing Options for Windows Media Player 11 on Vista?
  8. Mod Neophyte redwudz's Avatar
    USA
    Which version of Vista are you using? You need Home Premium or better to have installed DVD playback support in WMP. You would also then have Windows Media Center which is more often used for DVD playback in Vista. Windows often calls a DVD drive a CD drive until a DVD is inserted.
    Try using VLC Media Player. If it works, then you may be missing the MPEG-2/DVD codecs needed for WMP. VLC has it's own codecs. Media Player Classic should also work and is closer to WMP in format.
    Jan 2008
    Actually, I got another idea. I am going to use GOM Player instead to play DVD's without having any problems from now on.
