I am having problems authoring a dvd - PAL - 4 x 3
This problem is in relation to all my menu pages. Each menu page has 4 movie links.
Each link has a font of 40 and Comic (the problem occurs with any font of any size).
When i use group hot spot, the font and size appears fluffy / jagged around the edges.
I have set the font as follows:
COLOUR
FILL COLOUR - BLACK
DROP SHADOW: NO SHADOW
EFFECTS: NO EFFECTS
TRANSPARENCY: NORMAL
MAP
In the normal, Selected and Activated button states, the fonts still behave fluffy / jagged around the edges.
I have used Group hotspot before, but only with pictures, and had no problems
There is some other text of the menu, and when displayed on TV and PC, appears normal.
Any suggestions
It sounds like you are only creating the sub-pictures, which have a very restricted colour depth, and therefore don't have any real anti-aliasing. You don't notice the problem so much with clean edges and boxes or lines, but text and other symbols can do this. You can hide it to a degree if your backgrounds are created correctly so that the sub-picture blends more subtly.
If you look carefully at most commercial DVDs you will see that they try to avoid having sub-pictures sit too starkly on the menu because of this problem. Many commercial menus display this problem very clearly.Read my blog here.
Don't use 'absolute colours" like 255/255/255 or 0/0/0 for pure black. Each colour should be kept below 238 as a TV has less trouble to display it. Optimum colour palette is a matter of experiments as colours interact (background/links/subpicture)
guns1inger always disagrees with me
but I repeat: DLP doesn't render menu as good as other PC authoring programs.
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 22:02 -
DVD Lab Pro
By matthewjohn23 in forum Authoring (DVD)Replies: 5Last Post: 20th Mar 2009, 13:35 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 02:39 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 08:53 -
Q, for those who use DVD Lab Pro...
By GangstaRap in forum Authoring (DVD)Replies: 3Last Post: 1st Nov 2007, 07:15
