Why does Adobe Media Encoder include a black side-border for my NTSC DVD export of a 50i HDV project? I uploaded a frame grab: http://xs432.xs.to/xs432/08425/vlcsnap-3021465318.png
Also, what can author a DVD with no menu and no recode (when supplied an m2v and wav)? Thanks!
	1. Don't know.
 2. Try muxman, guifordvdauthor, dvdstyler, rejig.
	50i means it was originally PAL, and maybe the source resolution is 720x576 (or 1024x576)? Then the answer is that that's how it did the conversion resizing. Unless you use ITU-R BT.601-4 resizing, you get some small amount of black bars to the left and right. I don't use any Adobe products, but my guess is if there's an ITU or a 601 check box or template, and if you check it or use it it, when resized it won't have any black bars on the sides.
  Issues authoring Blu-ray disc from captured footageBy SportsorDeath in forum Newbie / General discussionsReplies: 11Last Post: 21st Feb 2012, 11:10
  Sony Handycam .avi to WMM to TNPGENC DVD Authoring issues. Please help...By Captain Tatonka in forum Newbie / General discussionsReplies: 25Last Post: 8th Mar 2010, 11:35
  Issues Authoring DVD with different resolutionsBy Smack2k in forum Authoring (DVD)Replies: 3Last Post: 11th Nov 2009, 03:24
  DVD Authoring/ MKV , multipile issuesBy thestation in forum Authoring (DVD)Replies: 2Last Post: 15th Mar 2009, 17:59
  Studio 11 Authoring IssuesBy mwboda in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 16:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
