I have a cd that will boot my xp computer into ntfs4dos or Dr Dos and read/write my ntfs partition, but I can't seem to see my USB memory
stick. I want to copy files from my ntfs partition onto my USB memory stick (not using Windows operating system). How can I do this in a simple way? I know I probably can do this in Ubunto LIVE, but want to try to do this another way.
Results 1 to 11 of 11
ntfs files are copied to the usb stick the same way any other file is. drag and drop, copy and paste, .... the stick may be formatted fat, fat16, fat32 or ntsc it doesn't matter. that is if if the os can see the stick. not all can use usb mass storage devices.
You will need some combination of boot OS with drivers that recognize the USB stick. Some mobos have different USB emulation modes available, but a DOS driver that will work might be hard to find.
This is a good example of where a minimal Boot disk is just TOO minimal.
The Ubuntu or Ultimate Boot CE would be more likely to work. -
Let me see if I get this...
You have an XP computer. It apparently has an NTFS partition which you wish to copy to a USB drive, but you don't want to boot XP and you don't want to boot Ubuntu, which you say will probably work but you don't want to do it. So the solution you want is to do this in an impossible way because doing it in a rational way is not an option for you.
Read the other posts from jimdagys and the conclusion is that either he is a complete moron or he's a troll. Either way, why are you people responding to this? If he's a troll, you're wasting your time. If he's a moron, he's too stupid to learn. I really thought that his "I put a USB stick in my PC and got a virus" thread was rock bottom, but I guess I just didn't give him enough credit. -
OK, I am going to try to download the UBCD. I understand that it has many tools on it. Which tool do I choose to be able to read/write ntfs and also see and save to USB memory stick?
UBCD will let you build a bootable CD that will boot and run XP *FROM THE CD* (i.e. slower that you HDD, but similar principle)...just use normal Explorer copy/paste/delete like you're used to to move files around. As for the USB stick, I *think* the USB drivers may need to be started manually after UBCD boots up...under the SYSTEM menu I believe(?)
Trev -
The Ultimate Boot CD I am familiar with boots a flavor of Linux, You may be thinking of a BartPE disk?
I believe, as I mentioned previously, that you will need to add NTFS4DOS to the UBCD disk.
Haven't tested the Ubuntu yet myself but it would appear that you can do the job from an unmodified ISO, no assembly required.
Linux usually boots with the necessary drivers. DOS does not. -
knoppix live cd has always worked for me. versions of knoppix after 5.01 can read/write ntfs. runs from the cd and can use to usb mass storage devices.
When you say,
"...you will need to add NTFS4DOS to the UBCD disk," is that the NTFS4DOS boot ima or the bsf that will need to go into the (boot sector?) of the UBCD? Can that be added with Nero or UltraISO? I used Ultra ISO and extracted 2 files out of the NTFS4DOS floppy, ima and a bsf. -
Why don't you just download a copy of knoppix live and and boot from it ?????Originally Posted by jimdagys
Converting FAT memory stick to NTFS
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2011, 01:47 -
dvp5992/37 - USB memory stick movie file size questions........
By tracnet in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Jun 2011, 16:58 -
Question about specific virus that affects USB memory stick
By jimdagys in forum ComputerReplies: 6Last Post: 27th Sep 2008, 00:07 -
question about fake USB memory stick
By jimdagys in forum ComputerReplies: 12Last Post: 31st Mar 2008, 00:58 -
question about USB download speed into memory stick
By jimdagys in forum ComputerReplies: 2Last Post: 7th Oct 2007, 21:38
