    Sep 2008
    i have used super to convert an flv file to an avi file. My only problem is how do i then burn it to a dvd to be able to watch it on a stand alone dvd player. thanx if possible step by step.thanks again.
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Use super to convert to DVD compliant, then use an authoring tool (to the left) to author to dvd. It is better to convert straight to DVD, rather than flv->avi->dvd (less quality loss).
    There are plenty of step-by-step guides to the right. Do a little research.
    Also, you've posted a few question that are fully covered in the guides. You should check the guides first before posting questions. Then, if you haven't found what you need, ask the question (it may even lead to the creation of a new guide).
