I have an avi (XVID) file that I want to play on my Playstation 3. The file plays fine on my PC and the audio is in sync. When I try to play it on my PS3 is states that it isn't a compatible file. So while it is an XVID file something isn't formatted correctly - at least for the PS3.
I've tried to convert it using VirtualDubMod but when I do that; first it gives me an error that the audio in the file is VBR and might have sync problems when I open it and then once I convert it to an AVI that will play the audio is off about 1 or 2 secs behind.
What are my options? I could try to align the audio files (I found some tips on how to do this) but that seems kinda hit or miss and might not work very well and is time consuming. I figure maybe I don't have the right tool or I'm using the right tool incorrectly. Any help would be appreciated.
Thanks in advance....
pinovecs@yahoo.com
ps - I have successfully created/converted files on my computer that play fine on the PS3 so I know I have good versions of various CODECs.
Maybe you should identify what is causing the problem? e.g. it might be the video (e.g. qpel, gmc), or audio (e.g. vorbis).
Use mediainfo (view=>text) for more information, and/or gspot on your file
vdubmod is old and hasn't been updated in years. Newer versions of vdub and avidemux handle vbr audio much better -
sorry...I'm kinda a newbie when it comes to conversion...or at least troubleshooting conversion problems.
I've used Gspot..should I post the file details from Gspot back here?
I also use VirtualDub but VDubMod seems more friendly.
What tool do people recommend for conversions? I said I used VirtualDubMod, but it really was via AutoGK front end.
Thanks again....
Chris
Audio out of sync after conversion
By user2008 in forum DVD RippingReplies: 5Last Post: 13th Nov 2010, 05:13 -
After conversion audio is out of sync
By videojunkie7 in forum Video ConversionReplies: 0Last Post: 23rd Nov 2009, 18:06 -
Audio Conversion out of sync
By Silsur in forum AudioReplies: 8Last Post: 13th Oct 2009, 17:45 -
force audio sync during conversion
By dtmp in forum Video ConversionReplies: 1Last Post: 5th Aug 2009, 16:52 -
WMV video and audio slightly out of sync on conversion to AVI
By Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 08:48
