Nice post!Originally Posted by poisondeathray
Results 31 to 37 of 37
All high compression codecs get a major portion of their compression by not encoding parts of the image that don't change from frame to frame. Ie, "this frame is the same as the last one, just change this, this, and this...". When almost everything changes between frames the compression scheme breaks down and you get lots of macroblock articacts.Originally Posted by kr236rk
Originally Posted by jagabo
thanks - so basically QT/VP6 'can't handle it'
R -
Don't lump QT with VP6, because "QT" - if you mean QuickTime - can encompass a variety of codecs, including h264/aac seen in the HQ Apple Movie Trailers (which is an "AVC Main" profile), or DV, Sorensen 3, h.263, etc... The quality can be good or bad depending on the source and/or codecs/settings used. The commonality is the the .mov wrapper (container). Not to sound cheesy, but "it's what's inside that counts"Originally Posted by kr236rk
update
preview window in Sorenson Squeeze can be resized by dragging its borders - you can make it huge
this compression software with its filters continues to look promising
later
Ric -
have now spent 3-4 days testing out the trial Sorenson Squeeze 5 software, and finally understood how to apply individual Sorenson filters to video clips, and watch them (in Real and wmv formats - mpg4 compressed and played but would not show any image at all in Real Player)
Sorenson hosts a brilliant if not bewildering (to me) selection of file types, if you are heavily into web uploads; but i was primarily interested in the filters, for 'tidying up' particularly troublesome pieces of video, and the filters do not seem to be that much more versatile in that respect, than those on my old Pinnacle editware. the contrast filter, for example, was excellently balanced and gave me deep darks whilst not bleaching out highlights
once learnt, Squeeze is easy to use - basically a drag'n'drop workout, and will compress you a choice of more dv file formats and sizes than you dreamt possible; you can also crop with apparent ease and choose a range of frame formats - from 4:3 to anamorphic 'big screen'
support was excellent to begin with - including a product forum - but tailed off, including the forum, after about 48 hours, due to the weekend? there is an instructional dvd sold separately available at about $100, if you feel so inclined
http://www.sorensonmedia.com/products/?pageID=1&ppc=5&p=20
R
Sorenson Squeeze 5.0 and QT
By rotuts in forum MacReplies: 3Last Post: 9th Dec 2010, 16:41 -
Sorenson Squeeze 5: Presets
By kr236rk in forum Video ConversionReplies: 1Last Post: 27th Oct 2008, 08:56 -
Sorenson Squeeze Problem
By seven_deuce offsuit in forum Video ConversionReplies: 0Last Post: 15th Nov 2007, 22:24 -
sorenson squeeze 4.3 problem
By Davide vr in forum MacReplies: 0Last Post: 12th May 2007, 21:55 -
Sorenson Squeeze 4.5?
By jupiter84 in forum MacReplies: 1Last Post: 9th May 2007, 02:46
