All the programs that I use will open a directory with the "List" view when I try to open a file. I prefer to use the "Details" view, so that requires that I go through the "Views" icon, then select "Details".
Is there a registry setting to change the default "Open Dialog" view to "Details"?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I assume you mean in Windows Explorer? Set your window to display the way that you like and then hold down the control key and close the window. You can also go to Tools / Folder Options / View and click on the "Apply to All Folders" button.
Google is your Friend -
I know exactly what you mean. I always wanted it to be set by the program.
ie. thumbnails for photoshop. Details for pretty much everything else
Only by using 3rd party software
Here's one http://www.cottonwoodsw.com/fx3summ.html -
No.Originally Posted by Krispy Kritter
I mean when you are in a program, ie, PhotoShop, and you want to open a file. The open dialog default view is "List". It is this setting that I want to be able to change.
Since all programs seem to have this default view in the "Open File" dialog, I am assuming that there is a registry key somewhere that can change it.ICBM target coordinates:
read my reply
No reg hacks are able to do it
One I read was to use ctrl/cancel, but that doesn't work
How to view files on "empty" 16GB memory stick
By jimdagys in forum ComputerReplies: 15Last Post: 15th Dec 2011, 08:35 -
Can't view "bonus video content" on Taylor Swift CD
By wild4trv30 in forum DVD RippingReplies: 11Last Post: 18th Jul 2011, 13:22 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Audio software that "overrides" default file-types/icons
By djdust in forum Software PlayingReplies: 0Last Post: 15th Apr 2011, 04:09 -
Easy way to default existing subtitle to "on" when backing up?
By Spoffo in forum SubtitleReplies: 1Last Post: 30th Jan 2011, 22:50
