Is there any way to upconvert a 480i output from and old DVD player to 1080i\P? Any outboard black boxes or any HD TV that will do it?
Most TV's will perform the conversion. Even with an upconverting DVD player, you should test which looks better, the DVD player upconverting or the TV.
Google is your Friend -
Originally Posted by wulf109
http://www.soundstageav.com/onhometheater/20060901.htm
Here's some information about these things:
http://www.avsforum.com/avs-vb/showthread.php?t=574222
and the AVSForums has an entire forum devoted to them:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=37
In my opinion, unless you're prepared to spend the big bucks for one, your best bet (unless letting the TV do all the work) is just to buy a newer and better DVD player, perhaps one of the good Oppos, or perhaps a Blu-Ray player. -
The reason that I ask this question is that I can't find a new DVD player that will properly handle Dual-layer burned disks. I tried a Toshiba HD player,Philips,Avayon,and Bravo and none of them play Dual-layer disks correctly. My old Apex Ad-660 with a Toshiba 1712 DVD-ROM play them flawlessly but only outputs 480i.
I guess what I'm really looking for is an upconverting DVD player that correctly plays burned Dual-layer disks.
The loaders used in current players are garbage. -
If you look at the cheaper brands or cheaper end of the branded market then you will probably find the upconvertors are not better and often worse than your TVs built in upscaler. Any cheaper product, beit player or TV, will generally have a very average upscaling capability anyway. You need to pay money to get quality.
Also, most players only upscale through HDMI, although some will do component. Over here they are few and far between - HDMI is definitely the connection of preference.
If you want to keep your current TV and player then you might look at AV amplifiers. Many of the newer ones have upscalers built into to take SD connections and output upscaled through HDMI.
But test drive them with some of your discs first to make sure the quality is actually an improvement over what you have now.Read my blog here.
And you shouldn't be having trouble playing any discs, SL or DL. I would question your discs/media before blaming the player. If you are using any DL media aside from Verbatim, that is the most likely problem.
Best outboard consumer capture device today? VHS, LD, camcorder and HD DVR
By cosmichippo in forum Capturing and VCRReplies: 4Last Post: 11th May 2010, 13:46 -
Blu-ray or upconverter?
By glp103 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Nov 2008, 19:14 -
Best HDMI upconverter DVD player...?
By snadge in forum DVB / IPTVReplies: 8Last Post: 8th Mar 2008, 21:00 -
upconverter dvd player/recorder recommendations...
By rubberman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jul 2007, 15:36 -
Using LCD Monitor with DVD Upconverter
By e39mofo in forum DVB / IPTVReplies: 1Last Post: 18th Jun 2007, 13:37
