now there's another problem that bugs me.I have ONE video which I wish to cut and join here and there.The thing
is,when I cut one part of the video,and rejoin them back(or even without rejoining back)there's this really annoying sound at the point where I cut the video.I dunno how to describe the sound but it's a really quick sound but it's really annoying meFor eg,there's this tv series and that person is talking and then suddenly there's commercial and after the CM,that person continues to talk.So I cut the commercial and when I play back on any media player,there's that sound again at that point where I cut the CM.So,while that person is talking,u can hear that 'popping(or whatever u call it) which is annoying.
I hope somebody can suggest on how to use this vdubmod to cut and join a single video without any weird sound at the edited point.I tried avidemux but the same thing happened.I need to do this as soon as possible cuz it's urgent
I can't live without my computer.
You did not mention the particular codec of the avi file you are editing, but I suspect it is a highly compressed format like divx/xvid, in which the edit point shifts to the nearest I-frame, instead of the exact frame.
More information about the video file type (which can be identified using GSpot) would be helpful.
Frame-accurate editing can be done with uncompressed AVI and DV-AVI files. If your source is already one of those, then disregard this post.
Further elaboration: The popping sound may be a split-second hunk of audio from the commercial you edited out, and while you intended to cut on a point where there is no sound from the commercial, the slipped I-frame edit point may be catching a little piece of it.
Just a theory, as I am not present to see how you are cutting the video.
Metadata editing in videos
By rockyrohit in forum EditingReplies: 14Last Post: 7th Nov 2011, 09:15 -
Videos encoded w/ Vdubmod = less saturated/vibrant? (Example video inside)
By ahphoto in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 10:28 -
re-editing compressed videos
By anotherkentpaul in forum EditingReplies: 1Last Post: 24th Apr 2010, 16:50 -
can't open any videos in vdubmod 1.5
By mr-scarface in forum EditingReplies: 8Last Post: 18th May 2009, 05:53 -
Editing DV AVI videos
By rjack in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2009, 18:49
