hi, i have vcd karaoke and i want to authoring it with dvdlab pro
what should i use / do if i want to make that dvd still can be karaoke
sorry for my bad english
While I do not have experience with the particular software you are using, I can tell you that VCD is halfway there as far as being usable for DVD. the only problem is the audio. I use TMPGEnc. copy the .DAT file from the VCD to your hard drive and rename it .mpg. Use TMPGEnc's tools to demux (seperate audio from video). Then use it to re-encode the audio to DVD audio specs (you can load the dvd profile to see the specs, I think its 48000/384, then when its done, use TMPGEnc again to remux the audio and video to produce a new mpg file. That new mpg fiel can be used as the source video for just about any DVD authoring program you might have as it will be one of the accpetable standard video formats for DVD authoring. Sorry I can not be specific, but I hope this helped.
Bill
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 10:02 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Aug 2010, 00:01 -
Karaoke DVD of China DVD Karaoke player
By d0ming in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Apr 2010, 08:17 -
how to convert LD karaoke to VCD karaoke ???
By sandmankeren in forum Authoring (VCD/SVCD)Replies: 1Last Post: 7th Aug 2008, 16:53 -
karaoke VCD to DVD
By biemew in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2008, 06:16
