Hi all, I have a Asus U6V-A1 laptop running on XP, and the graphic card is Nvidia Geoforce 9300M GS with the latest driver installed. I tried to connect the laptop to my TV (42' Westinghouse 106.7 HDTV 1080P), however the TV screen constantly flickers! It will display properly for 2-3 seconds, then go black screen for half a sec, then flicker back on, then repeat the process. Any idea how to fix this? Any help will be greatly appreciated!
Have you tried different resolutions, refresh rates and different output modes like clone, just hdmi output, etc?
That might be an HDCP issue. Try the latest WHQL certified video drivers for your laptop.
Since the U6V only have Vista drivers and I've downgraded it to XP, I had to install the modded inf video drivers. After your suggestion that it might be a HDCP issue, i decided to install vista to another partition and try dual boot. Well the HDMI TV-out worked with Vista, so I might really have been a HDCP issue since the Vista had WHQL certified video drivers. But interestingly, after I installed Vista, even TV out from XP works fine too! However, when I TV out from Vista I get bot video and sound, but when I TV out from XP, I get video only. I have the driver for Nvidia HDMI installed on my XP and it runs fine when I play 1080p BDrips on my laptop. Any suggestions?
Thanks! -
Part of the HDCP spec is for the devices to monitor the connection and shut down if there is evidence of tampering. As I recall, some drivers were a little too sensitive to noise or low signal strength and would disconnect randomly. Maybe your original problem was related to this.
Regarding missing audio, does your laptop have native HDMI out or are you using a DVI to HDMI cable? There is an issue with Nvidia drivers and DVI to HDMI cables:
http://forums.snapstream.com/vb/showthread.php?p=285484
Capture software for HDMI IN port on laptop
By Alan-B in forum Capturing and VCRReplies: 3Last Post: 6th Oct 2011, 21:43 -
Is it necessary for a laptop having an HDMI port if it has no Blu-ray drive
By coody in forum ComputerReplies: 7Last Post: 29th Nov 2010, 20:35 -
Video tearing on HDTV (connected from laptop using HDMI)
By dzsoul in forum DVB / IPTVReplies: 8Last Post: 14th Sep 2010, 03:40 -
Adding HDMI port to HP Laptop
By cadetgideon in forum DVB / IPTVReplies: 10Last Post: 12th May 2009, 23:21 -
How to connect VGA port on laptop to Svideo port on tv
By hulk420 in forum ComputerReplies: 4Last Post: 5th Jun 2008, 15:07
