Ok, for the longest time I used to be able to just right click on an .avi and goto properties and it would tell me the frame rate so I would be able to convert to VCD. But recently it just stopped doing that, now under properties all the fields are blank. Does anyone know how I can get the property settings back. And if you dont know that do you know of any software packages that can give the fram rate infor to me.
Thanks in advance
Open the avi in VirtualDub and then select file > file information.
Remove text from file properties
By Pegsitron in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2010, 07:29 -
Change File Properties/Information for Video Files
By MrRedPants in forum EditingReplies: 5Last Post: 16th Jun 2010, 23:33 -
AVI video properties missing
By Ayeohn in forum DVD RippingReplies: 3Last Post: 19th Dec 2009, 03:58 -
The Summary tab on a Windows XP video file Properties page is missing!
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 18th Oct 2008, 22:11 -
Lost Summary Tab on .avi properties
By blueprint in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2007, 16:25
