OK so I bought the Canon HV20
New to transfering video from the device to PC. My GA-K8N Pro-SLI F4 has firewire, but I simply assumed that this meant that I already had some sort of connector from the back. I guess I was mistaken?
So, as a newbie, what steps should I take? Do I have to buy a seperate card of some sort? Or should there have been something in my mobo box (Checked, but nothing there)...or what?? HELP!?!?!
Smile
Smile -
Unless you still have the ribbon cable
http://c1.neweggimages.com/NeweggImage/productimage/13-128-301-02.jpg -
Looks like the firewire port is a header on the MB, you might have received a connector bracket in the box (it's on the options page). If not go to a computer store and buy one, would be cheaper than a PCI card.
it should have come with a back panel connector with ribbon cables attached that hooks up to the m.b. and goes into an empty slot cover.
Miscellaneous
Cables included 3 x IDE cable 1 x floppy cable 2 x Serial ATA cable 1 x USB / IEEE 1394 panel
if you don't have one you can get a front panel to go into a 3.5" bay that you can hook into the m.b. connectors. newegg has them.--
Lost Audio on kid's video project. Confused about : .HO. .adv, .HDP files?
By tmh in forum AudioReplies: 2Last Post: 7th Dec 2011, 18:50 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Capturing using firewire but lost the date time on the screen
By nobody40 in forum Capturing and VCRReplies: 2Last Post: 13th May 2009, 12:01 -
HDMI connections
By Prot in forum DVB / IPTVReplies: 2Last Post: 20th Feb 2008, 18:06 -
HD connections?
By James in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 13th Nov 2007, 18:02
