Hello everyone. I'm having such hassles with my video converting at the moment, I really don't know what else to try. Hopefully you guys can help me out.
I have captured an interlaced video with HuffYuv in Dscaler (it's the only program that allows me to capture PAL60), and then passed it through VirtualDub with Smart Deinterlace. Again with the HuffYuv codec. The size is 640x480 and the duration is just under 8 minutes. The quality is excellent but obviously huge in file size (7+GB).
I've tried various methods to convert this to WMV for distribution over the internet, but I can't seem to get a file size/quality ratio that I'm happy with.
A quick pass through Movie Maker with 'high quality video (large)' setting, was, although great in quality, over 250mb in size. This is still too large for me, but with the settings any lower, the quality really suffers and I see squares all over the screen when the action heats up. I assumed that the lack of audio options is probably what's keeping the file size up, so I decided to try Windows Media Encoder and change the audio output to 128kbps (video set to 1500kbps).
However, I think there must be something wrong with it because when it's finished and I go to check the result, the video is never larger than 5kb!I've tried it 5 times now and keep getting the same problem. It says it's going to do 2 passes but only manages one before stopping. Anyone have any ideas on what's wrong?
Tried one pass in wme? Does it work? It maybe don't like your source file.
Or else can you try encode360 or wmnicenc.
Or why not make a flash with mp4 h264 and aac audio? https://forum.videohelp.com/topic355179.html
That sounds like a cunning plan, Baldrick. I will check those out this evening. Thank you. 8)
I have to say thanks again, Baldrick. Mp4 h264 is absolutely amzing! Exactly the sort of thing I was looking for. I will definitely be donating some money to that project. Best app ever! 8)
This site always helps me when I need it. Thank you very much.
Problems with conversion from wmv to MP4
By Dr_Zocki in forum MacReplies: 2Last Post: 9th Feb 2010, 05:27 -
FFMPEG decoding WMV to FLV problems
By motorg in forum Video ConversionReplies: 3Last Post: 10th Aug 2009, 22:30 -
WMV/MPG problems
By Metallian MetalGod in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2008, 22:35 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 04:48 -
WMV To DVD Format - Problems
By Lennoxtown in forum Video ConversionReplies: 5Last Post: 5th Nov 2007, 12:52
