When I run disk cleanup there are some compressed files listed. Can I delete these files without messing my PC up?
I'm a SPAMMER
Depends on what they are. I would decompress a couple and see what's in them. Also depends where they are located. If they are within the Windows folder, they may be something needed. Lastly it would depend on how big they are. If they are small, I probably wouldn't bother to remove them.
And welcome to our forums.
Within the Disk Cleanup application? Do you mean there are compressed files listed there (what section?) or that there are files that can be compressed (Compress old files section)?
Google is your Friend
VHS Cleanup, What can i do?
By Asesinato in forum RestorationReplies: 115Last Post: 5th Apr 2012, 13:31 -
help with dvd cleanup
By jszorady in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2011, 13:32 -
VHS to DVD Cleanup?
By LCE in forum RestorationReplies: 3Last Post: 19th Dec 2009, 02:35 -
Codec Cleanup
By jieve in forum Software PlayingReplies: 2Last Post: 14th Aug 2009, 17:18 -
Disk Cleanup Missing in System Tools
By bevills1 in forum ComputerReplies: 4Last Post: 7th Jun 2009, 18:30
