I do not know step one of using Adobe Photoshop. I have a huge but probably easy question to answer. I want to use a picture for the menu background. I go to File>New and select the NTSC "template." Now, I have tried a gazillion ways and read hours of tutorials. HOW DO I GET A PICTURE AS THE BACKGROUND?
You click on File->Open and open your file into a new image in photoshop. Press ctrl+A (Select All) and then Edit -> Copy. Switch to your empty NTSC template image, and click on Edit -> Paste. Flatten the iamge so you have only one layer (called Background) and your image will be in it.
Read my blog here.
Thanks guns1inger. That worked.
Now, is there any way to have the picture automatically resized to fit? When I did as you said, it only filled the "template" with a segment of my picture.
New Adobe Photoshop image deblurring algorithm
By poisondeathray in forum Latest Video NewsReplies: 3Last Post: 13th Oct 2011, 23:12 -
Changing Photoshop background colour
By Rudyard in forum ComputerReplies: 4Last Post: 15th Jun 2009, 22:50 -
Question how to change background menu picture on DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 7th Dec 2008, 23:55 -
Adobe Photoshop Elements 6
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2008, 04:15 -
Problems with Adobe Photoshop Trial Download
By kerrex_2006 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2007, 11:19
