  1. Member romanstopme's Avatar
    Mar 2008
    i have an audio cd with tracks on it is there a way to take those tracks and turn it into one big audio file
    USA
    I assume you mean merging all the tracks into a single audio file? Most audio editors should be able to do that. The freeware Audacity is one choice. Or you may find a CD ripper that will do it in one step. Take a look at Winamp or just do a internet search for ' CD rippers '.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    EAC Exact Audio Copy will rip a cd to one large wav file or if you already have a bunch of wav files on your pc you can load them all into AddaWav at the same time, as opposed to one at a time with most programs, and it will join them all into one large file also.
    I don't know why they have never put AddaWav in the tools section but....
    http://www.versiontracker.com/dyn/moreinfo/win/12040
