Hi,
have a project to transfer vhs footage to dv. want to experiment with C-VHS format, but i need a c-vhs cam which has manual shutter speed options, alongside the standard AE modes. does anyone know of or remember such a camera that i could look for, please?
thanks
Ric
Results 1 to 13 of 13
VHS-C is fairly old technology.
I would try EBay to see what might be available used and then check their specifications. What is going to be your method of transfer to DV? Since this is in the DVD Recorder forum, I'm guessing a DVD recorder, which makes the DV part a bit odd. Or are you in the wrong forum? I can move this thread to another forum if you like.
VHS-C isn't really a format. It's just a smaller VHS cassette. You will also need a VHS-C adapter to play them in a regular VHS deck.
I appreciate a urge to go 'retro', but unless you already have VHS-C cassettes, you would really be better off with a DV camera, JMO. -
Thanks Redwudz
bests
R -
Thanks for the further information and good luck with your project. This would probably be better in our Capturing Forum, moving you.
Hi to all on 'Capturing' - sorry, missed this forum and have been kindly moved
yes, i know it's easier to get professional/commercial transfers - and they are invariably excellent - but the subject fascinates me and i like that 'home made' look to small format movies [ciné film]
am also fascinated by 'compression', 'codices' and digital editing generally, with the hope that the more learnt the less mystery when digital glitches appear
thanks
R -
If what you want to achieve can't be successfully compressed to DV, then you have no hope with DVD, Vimeo, YouTube, etc etc which are all far more compressed. So how on earth will anyone else watch this in the 21st century?
TBH I've never seen anything which DV is really horrible with - maybe the "artefacts" are actually tape faults (drop outs), capturing faults, rendering/decoding faults, or issues with interlacing?
Cheers,
David. -
Originally Posted by 2Bdecided
i re-invented the wheel last week, going from dv cam to vhs back to dv again, and off-loading a beautifully useless brand new Sony Handycam to the Bay in the process (fully AE, no manual control on anything); went back to my old semi-AE Canon cam and at last started getting some sense out of what i'm doing; it does however seem that i may need a slightly faster processor than P4 at times, and am about to experiment with Sorenson Squeeze 5 on another pc; my Pinnacle 9 av/dv is donkeys years out of date now, but i still like editing with it - but it's time for a change, things have moved on since 2002
think the compression issue is increasingly okay - a lot of the problem was also in the source-capture material, which is now beginning to behave itself. these are home-made experimental projects
http://www.vimeo.com/1996923
http://video.google.com/videoplay?docid=-8156162995813111492 -
How about an old Video8 or Hi8 cam? When using the live output from a Video8 in camera mode, the resolution is very good (much higher than the Video8 tape format).
John Miller -
Originally Posted by JohnnyMalaria
the attraction of C-Video was it's complete compatibility with full size VHS VCR, a format/medium i still have a soft spot for - but Hi8 would give better visuals: the problem with VHS cameras was the zoom, generally below 10x. My Canon dv cam has 20x, which just about sees me through
many thanks
R -
Personally, I'd use my JVC S-VHS-C camera. They were pretty pricey back in the day, but may be affordable used now. It had a TBC, and worked really well.
The VHS adapters often would help a VCR eat the tape, more than anything else. I've got a high-end adapter from JVC, and use it in my Panasonic deck when the camera rejects a stubborn tape.Want my help? Ask here! (not via PM!)
From the examples, I think the OP wants intentionally bad looking video. The artefacts are part of what the OP is aiming for.
Am I right kr236rk?
If not, there are far better ways of getting 8mm film into a PC.
And, of course, if this is "new" footage, shoot HD - not 8mm film > VHS-C > DV > PC!
Cheers,
David. -
microwaves do relatively nothing apart from melt the cassette casing
the attraction for me re ciné film is the photographic emulsion, which is a subtle medium; dv [and HD] is great but ultra graphic and would not suit my brief, but the semi AE cams are great for transfer ...
or were - the trend today is for complete AE
thank goodness i held onto my Canon mv830i - which has manual control over shutter speeds, if you want it
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 16:27 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
