Hi all, I'm having a bit of a problem. I have the Intensity card from BlackMagic (Just Intensity, not the Pro) and I'm having trouble capturing audio. I'm capturing in Adobe Premiere CS3 via HDMI. I can capture video just fine but whenever I play the file back there is no audio. There is also no waveform when I drop it onto the timeline.
Any suggestions on how to fix this?
Specs:
Operating System: Windows XP Pro SP2
CPU Speed: Q6600 2.40 GHz Quad Core
Harddrive space: 500GB
RAM Memory: 4 GB
Video Card: GeForce 8800 GTS
Hey ercdill,
I just bought a BlackMagic Intensity and received it yesterday. I am having the same problem with capturing audio from the Xbox 360 via HDMI. Where you able to figure out the problem?
Thanks!
Corey Kinard -
No I wasn't, I'm still having this problem. Any help would be appreciated.
For the ps3 you have to select whether or not audio goes through the hdmi output, fiber optic, or composite/component cables.
I only have the nonhdmi 360 so I don't know the differences on the 360 hdmi model. Have you ensured audio is outputted through the hdmi cable and not the fiber optic?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You can't choose how you want to output audio from the 360, you can only choose what you want to output. It'll then use whatever connection is available to output the signal). They give you the option to output Digital Stereo, 5.1 and 5.1 with WMA (I think). I've tried all three output signals...nothing.
I also would like to put I am sharing the same problem with the audio.
Black magic intensity pro + xbox 360 & monitor
By Tehdailyscrub in forum Capturing and VCRReplies: 1Last Post: 22nd Mar 2012, 17:38 -
Black Magic Intensity Pro: Issue with xbox 360 settings
By dreamboss in forum Capturing and VCRReplies: 2Last Post: 14th Mar 2012, 19:50 -
Capturing PC1 from PC2 using a Black Magic Intensity Pro card
By Ccat in forum Capturing and VCRReplies: 11Last Post: 9th Jun 2011, 07:03 -
Black magic intensity pro xbox 360 help
By razerpro in forum Capturing and VCRReplies: 5Last Post: 25th Jun 2010, 10:20 -
Black Intensity HDMI connecting question to HDTV/360.
By bradyfan123 in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2008, 12:49
