I am interested in connecting my television and pc. I have a VGA connection on my PC and a S-Video connection on my television. Other than buying the cable, what else would I need to do?
VGA does not connect to S-Video without a frame sync converter box. Expect marginal picture quality.Originally Posted by CoDe-DRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If all you want is S-video to TV then get a video card with S-video out... they are cheap.
On second thought, take a harder look at your P4 computer, you may have an S-video out, they are very common. -
In case it isn't clear, cables advertised as VGA to s-video do not convert VGA signals to s-video signals. They are for use with specific graphics cards that output s-video on an otherwise unused pin the VGA connection. Very few graphics cards implement this feature.
ok. I had just seen cables online that were VGA to S-Video. I'm pretty sure I dont have an S-Video connection on my computer and I've looked EVERYWHERE! I'm not too familiar with S-Video cards? What are they exactly?
Many graphics cards include s-video outputs. Often on a 7 pin mini DIN rather than a 4 pin mini DIN. Four of the pins correspond to an s-video cable. The other pins are usually for component or composite outputs.
http://en.wikipedia.org/wiki/Mini-DIN_connector#7-pin_2
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048+1232814103&Conf...Subcategory=48 -
This has been addressed dozens of times. Go ahead buy it and learn that it works for maybe 1 % of those with projectors.Originally Posted by CoDe-D
Then come back and listen.Recommends: Kiva.org - Loans that change lives.
I didnt say I was gonna buy it. Thats why I asked about it. God bless my soul I'm not a television/computer geekOriginally Posted by edDV
problem connecting computer to telly using vga cable
By xtube in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2010, 04:01 -
Connecting DVD with VGA output to computer monitor.
By danyalos in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2009, 13:12 -
Connecting laptop VGA to TV S-video
By tezarin in forum Newbie / General discussionsReplies: 7Last Post: 2nd Apr 2009, 17:09 -
Connecting laptop (vga) to television (no s-video)
By MD2000 in forum Newbie / General discussionsReplies: 5Last Post: 1st Aug 2008, 18:48 -
Query about connecting VGA outputs to DVI inputs
By aceizace in forum DVB / IPTVReplies: 4Last Post: 19th Sep 2007, 16:00
