  1. Hi,
    I would like to scan & clean my WinXp Pro registry from all the garbage which will have undoubtfully gathered over the past 2 years!
    So, which do you guys recommend? A free one preferably...
    Thanks in advance.
  2. ccleaner is a good free one
  3. I suggest regedit.
    It is free and built into windows.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  4. Member wtsinnc's Avatar
    Nov 2006
    Gotta go with CCleaner. Free, easy to use, cleans the registry and file fragments in separate operations. I consider it a must-have.
    Two others that I like as well are Wise Registry Cleaner (there is also a Wise Disc Cleaner- both free), and Eusing Free Registry Cleaner.
    Remember to back up the registry before using any cleaner.
  5. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    RegCure and JV16. one after the other.
