Hello, I'm a newbie.
I've an AVI (Xvid) file of 801 MB, the video quality is very good but, the audio is excellent. I wanna downsize the file to less than 700 MB so that it can be saved in a CD-R.
According to AVI ReComp 1.4.4, a freeware, which I've recently downloaded, the video size of that file is 565 MB and the audio size is 231 MB. How can I reduce the audio size ONLY ??
Audio specs of the file are below...
Type: ac3
Bitrate: 384 kb/s
Bitrate mode: CBR
Channels: 5.1 (surround)
Sample rate: 48000 Hz
How to change the channels from 5.1 (surround) to 2 channels (stereo) along with the Bitrate and Bitrate mode from CBR to VBR or ABR (which one is better ??) ???
Thank you!
Peace.
Results 1 to 17 of 17
Just to clarify Baldrick's instructions, you have to downmix the audio to stereo:
1) open in avidemux
2) set video sidebar to "copy"
3) set audio sidebar to "mp3"
4) press "filters" under the audio section, in the mixer dropdown menu, select "stereo". You can press configure also, to choose your bitrate (audio filesize)
5) set format to "avi"
6) press save with extension (e.g. "myfile.avi") -
For a given bitrate, AAC will give the best quality, but it's not compatible in .avi container. You have to use .mkv or .mp4
In terms of better compression AAC > MP3 > AC3
Filesize = running time x bitrate ; so it's not surprising that if you use the same bitrate they will be the same size
You have to add both audio & video. -
Will AAC be better than others @ 128 kb/s as well?
I won't mind changing the container to .mp4
In fact I'm now thinking about changing the codec to H.264
Will it bring the file size further down without affecting the quality? -
Originally Posted by moiz
For the audio (192kbps MP3 vs. 128kbps AAC) it's tough to say, do some tests and judge for yourself.
You will lose a bit of quality if you re-encode the video, because h264 is a lossy format (unless you use lossless mode, but filesize will increase a lot)
If you used the original source (ie. DVD or blu-ray), using h264 will be better than the XviD you have now at the same bitrate. -
OK. I'm not touching the video or it's codec (Xvid)! File size: 565 MB
Will change the audio to 192 kbps AAC, as you said that it's better than MP3 and AC3. File size (would be): 115 MB
In total (audio + video) the file size would be just more than 680 MB, the issue of saving it in a CD-R is solved.
Now, the question is...
What effect would the change in container make on the video (Xvid) ??
And which container is better for PC playback with above settings, .mp4 or .mkv ?? -
.mkv has more utility (supports more things), but overhead is slightly bigger (minimal, like a few kb)
Either should be fine for PC playback, .mp4 might be better for older/slower systems (again difference is minimal)
You can do test it out yourself - it only takes a few minutes since you are only re-encoding the audio. -
If you think you might ever want to play the video on a set-top Divx/DVD player you should use the AVI container and MP3 audio.
poisondeathray,
If this is the case then I'll test .mkv & .mp4 on my PC and will report back!
Thank you very very much for your help!
jagabo,
Hmmm... I'm not planing to play it on DivX/DVD player, only on PC.
Thank you for your concern.
Something is wrong with THE file whose audio has to be changed. When I press 'Save' button ---> Avidemux (Not responding) !!!
But Avidemux is working fine on other AVI files no matter what their audio or video codec is.
Anyways, I've used AVI ReComp for THAT file.
As far as the .mkv & .mp4 comparison is concerned, I tested them with 2 other files and I'm unable to find any difference, but, remember I'm a newbie!
Thank you!
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
PS3 won't play audio from this burned AVI (specs included)
By bound4h in forum MacReplies: 5Last Post: 25th Jul 2010, 10:42 -
Can't hear audio on PS3 from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2010, 15:49 -
PS3 won't play audio from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2010, 20:16 -
Please Help !!! How to change the audio format (only) of an Xvid/AVI ??
By moiz in forum User guidesReplies: 3Last Post: 15th Oct 2008, 13:30
