Hi, i'm doing some keying using multiple keys/settings.. isnt there a way to take those effects and apply them all to anohter composition/file?
Hi
You can highlight the effects, select COPY from the edit menu, select the layer in the composition, then select PASTE from the edit menu. This should also work for multiple selections.
Brainiac
Help in rendering in After Effects!
By surferadi96 in forum EditingReplies: 5Last Post: 29th Jan 2012, 11:36 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
Help with editing and effects
By coppermouse in forum EditingReplies: 4Last Post: 19th Jan 2010, 16:28 -
.DV file from after effects
By nwo in forum EditingReplies: 2Last Post: 13th Jul 2008, 12:03 -
Do I need After Effects?
By hanexs in forum Newbie / General discussionsReplies: 13Last Post: 3rd Feb 2008, 22:06
(better late than never)
