Hello, I'm a newbie.
I've an AVI (Xvid) file of 801 MB, the video quality is very good but, the audio is excellent. I wanna downsize the file to less than 700 MB so that it can be saved in a CD-R.
According to AVI ReComp 1.4.4, a freeware, which I've recently downloaded, the video size of that file is 565 MB and the audio size is 231 MB. How can I reduce the audio size ONLY ??
Audio specs of the file are below...
Type: ac3
Bitrate: 384 kb/s
Bitrate mode: CBR
Channels: 5.1 (surround)
Sample rate: 48000 Hz
How to change the channels from 5.1 (surround) to 2 channels (stereo) along with the Bitrate and Bitrate mode from CBR to VBR or ABR (which one is better ??) ???
Thank you!
Peace.
Closed Thread
Try with VirtualDubMod>open file>Streams>Stream list>save wav..
Use something like DaudioK, import wav>set to desired bitrate and save new wav..Now while still in VDM >Streams>stream list>disable 1st audio track and ADD new wav >Ok..In video setting choose "Direct stream copy" and save new AVI...good luck!" Who needs Google, my wife knows everything"
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
What the best format to convert to, AVI(Xvid), MP4 or MKV
By adamf154 in forum Video ConversionReplies: 2Last Post: 1st Mar 2010, 17:48 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
convert XviD to DVD format but lost audio track 2
By zenghe in forum Video ConversionReplies: 2Last Post: 3rd Mar 2009, 17:34 -
Please Help! How can I change the audio specs ONLY of an Xvid/AVI ??
By moiz in forum Newbie / General discussionsReplies: 16Last Post: 17th Oct 2008, 15:30
