  1. Member kippard's Avatar
    Dec 2005
    Anyone know what app for Mac can export a Premiere Pro CS3 (for Mac) timeline to DVD (VOB, one step encode and author a la Procoder)? Thank you!
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Huhn?
    If you have Premiere Pro, instead of FCP, for mac,
    can you not export the Timeline straight to Quicktime Movie,
    and then Drag and Drop into Toast to make a DVD?
    Or for that matter, Premiere Pro export to .m2v/.ac3 and then
    drag drop into Toast, iDVD's (magic dvd), ffmpegx, VisualHub, etc.?
    Perhaps your asking a one to two step process, but there is always
    going to be either a half step or a third step, as the NLE does one part,
    then the DVD Authoring will do another?
    Or are you asking about going simply Timeline to Encoded VOB, then
    ready to put into a burning software? Like FCP Timeline to Compressor,
    then to DVD Studio Pro?
    Premiere Pro I would hope would have a Compressor type app or Sorenson Squeeze
    included , but if not you can go Premiere Pro Export
    Timeline to Quicktime and from there, use QT Pro, ffmpegx, VisualHub,
    to make your VOBs.....
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. Member kippard's Avatar
    Dec 2005
    Thank you! What settings should I have for the quicktime (50i HDV project)? Thanks again,
