    Oct 2008
    I would like to know how i can, if i can hook up 4 laptops to one tv and run them independenlty withinin a picyure in a picture mode. I have a Sony KDL 60 and 4 Sony Laptops. I want to see all the screens at the same time. Is this possible? If so How?. Running Vista Premium on all laptops 3.0 CPU and 4GB Ram
    Oct 2008
    Indonesia
    Maybe you can read this :
    geekwithlaptop.com/how-to-connect-laptop-to-tv
    thank you
    Jul 2001
    ashmichael,
    I think that your beyond the simple pc-to-tv question. What you want can probably be done easy enough with PIP with some TVs for two inputs. Some sets will even split the screen vertically/horizontally between two inputs. Not sure about your Sony.
    However, I doubt you'll find that with a regular consumer set you'll be able to do four. My guess is you'll need some 4-way video muxer (no idea if that's even the right terminology...) that will take the four inputs, downscale them to 1/4 resolution disply them as one video stream over a single input.
    Sounds expensive. (to me anyway...)
    EDIT:
    Doesn't look like I was too far off, and not so expensive after all. You have a couple of options:
    1 - 4-way manual switchers are pretty cheap and can be found almost anywhere. You simply plug all four laptops to the switch and you can display one at a time manually. Can be had for about US$5 if you look around.
    2 - I found this at a UK site (I'm sure there are US equivalents) that provides exactly what you were looking for. Its a autoswitching 4-way video muxer that can record or display 4 simultaneous video streams. You'll need to look for you exact needs (vga or hdmi, sound/no sound.....).
    http://www.sctltd.co.uk/acatalog/SwitchersQuads.html
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
