  1. I have a PC with Intel 82045G express chip set that has onboard video.
    I would like to get a second monitor on it.
    But I read if I try to add a (PEG) PCI express graphics card, it will disable the onboard video.
    Is this true for all onboard video ?
    Does it means I have to get a old PCI video card to add a second monitor ?
    (My Office PC use a dual head PEG, but that is expensive)
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Look for an option in CMOS Setup.
    http://www.kiva.org/about
  3. Windows Vista has this feature if there is conflict or some driver is corrupted it will disable it. If your new video card is capable of driving 2 displays and has output for it you are ok.
    Jan 2006
    Northern Pacific SW
    I don't think you can run two separate one-head video cards in one computer - or - onboard video and a PCI or PCIe card for dual monitor setup. I've never seen it (also never tried it), but I'm pretty sure it's a no go.
    I've had good luck buying dual head cards that are one or two generations behind the expensive latest and greatest cards. Performance is good at a much lower price. I do find I have to dig a bit on Newegg.
  5. Very rare that both will work. New card to drive two monitors relatively inexpensive.
