Hi
I use my digital camera to take videos. I have made several attempts to join about 30 small clips. I have tried DGindex, tmpgenc and Dos command copy /b *.MPG all.mpg.
Only the dos command seems to produce a mpg that is in has video and audio in sync.
I then use virtualdub with the antishake filter then I save in uncompressed format. This produces video and audio that seems to be ok at the start but by the end is way off. Very similar to the way the audio and video were off by using tmpgenc to join.
Can someone suggest something that I could try to correct this problem.
Thank you.
	I have created the mpg with mpg2cut2. When I open it with vdub 1.8 it only opens the first clip not the entire movie. If I use vdub 1.5 it will open the entire movie. I am deshaking now so I won't know until sometime tomorrow if it will be ok.
 I could not get vdub to append with the plugin. Not sure how to do that.
 Thanks for the quick reply
  Ripboot after conversion video & audio sync is out by 1 seconds ???By yamyoume in forum Video ConversionReplies: 5Last Post: 17th Oct 2011, 15:32
  Audio/Video Sync Issue with .mts File ConversionBy arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 10:52
  i captured a video from reciever in .mpg format, [ a conversion problem] !!By aSem-1 in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 17:22
  Conversion to MPG puts video out of syncBy ral315 in forum Video ConversionReplies: 5Last Post: 5th Aug 2007, 20:18
  WMV video and audio slightly out of sync on conversion to AVIBy Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 09:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
