No need to do that,routers can cause problems too,no issues at all with my sw firewall.Originally Posted by reboot
Results 31 to 52 of 52
My hardware router does several things. It uses NAT (Network Address Translation) which puts my computers on a Intranet, so they aren't exposed directly to the Internet. It supplies separate addresses for my computers, and it blocks two of them from Internet access (Servers). But it doesn't block malware.
I use a software firewall for that, along with other antimalware programs.
Yes, you can do quite a bit of configuration with the router settings, but it isn't continually updated like my software firewall and it's a lot harder to set up. JMO, but you need both a hardware router and a software firewall.
MS will tell you the Vista firewall blocks outgoing packets, but that's not entirely true.
To keep their business customers happy, they made outgoing blocking pretty much useless. http://www.zdnet.com.au/news/security/soa/Vista-firewall-shackled-due-to-customer-dema...9252954,00.htm
its ( a router) not supposed to be updated, its not application based. harder to set up?a software firewall is only useful when the malware is already present on your computer and by then for most users------ its too late.you can do quite a bit of configuration with the router settings, but it isn't continually updated like my software firewall and it's a lot harder to set up
Originally Posted by Poppa_Meth
It is updated continuously.
It is up to version 1.6.
You must be joking.
I use a router and the Vista SP1 firewall.Believing yourself to be secure only takes one cracker to dispel your belief. -
The Spybot program is updated, but the technology it uses it far behind other applications now. It's scanning engine just isn't up to par. Pretty much any PC I scan with Spybot now mainly picks up tracking cookies. Run SAS on the same system and it can find things Spybot doesn't even see, much less do anything about. Spybot is still decent. But there are much better options now.
You must be using an old version, because I use it all the time on client's computers to get rid of products such as antivirus XP2008 and so forth.Originally Posted by Poppa_Meth
Let's just agree to disagree.
This has veered off course...
The topic is firewalls, not antispyware programsBelieving yourself to be secure only takes one cracker to dispel your belief. -
Yeah, what redwudz said!!!
johns0, what, specifically, don't you like about routers? I assume you had a difficult time setting one up once, and have hated them ever since?
Enjoy your SW firewall, until some smart hacker finds a way through it.
Can't be done using a router/firewall. Read what redwudz says above.
I also use anti-malware/spyware, but no software firewall, because a firewall does not stop malware/spyware from infecting your computer. It may stop information from being sent OUT, but even that's doubtful with most firewalls only concerned with what's comming IN.
Try SuperAntiSpyware, or Malwarebytes, or yes, even an updated Spybot S&D.Cheers, Jim
My DVDLab Guides -
I do a lot of service calls and routers cause a lot of problems due to bad firmware and design in a lot of models and makes,i dont need a router cause i know how to protect my computer from hackers and dont assume i will get hacked and dont know much about routers.Originally Posted by rebootI think,therefore i am a hamster.
What do you want to know about routers? I will be happy to teach you.Originally Posted by johns0Believing yourself to be secure only takes one cracker to dispel your belief.
I have never had a router give problems because of "bad firmware". I have had problems because of shoddy upgrade procedures, and flashes with the WRONG firmware, and always on the rebranded junk. Buy a Linksys or D-Link, and you're probably good for 5 years or more.
"i know how to protect my computer from hackers and dont assume i will get hacked"...
You're precisely the type of person that WILL get hacked, because you assume you're protected with some software.
As Dv8ted2 mentioned above, what would you like to know, I'd be happy to teach you.Cheers, Jim
My DVDLab Guides -
I already know how to set up routers including wireless with encrypted keys,please dont assume i know nothing and you would teach me,i have set up many routers on service calls and most work with no problems,its the low cost routers that give the most problems and i remember those more so i guess i'm a little biased.
What i meant to say before is i know a lot about routers and dont assume i dont know much about them.I think,therefore i am a hamster. -
I have oneWhat do you want to know about routers? I will be happy to teach you
linksys Firmware: DD-WRT v24-sp1
under Firewall Protection (SPI is already on )
is it necessary/ok to turn on
Additional Filters
Filter Proxy
Filter Cookies
Filter Java Applets
Filter ActiveX -
Proxy, only if you're using one.
Cookies are harmless, ignore it.
Java is necessary for some websites, your call.
ActiveX is necessary for some websites, your call.
IE already has filters in place for ActiveX, as does Firefox.
Java has it's own settings, go into control panel and look.Cheers, Jim
My DVDLab Guides -
I wish it didOriginally Posted by MJA
I still havent found it anywhere -
na, not really a gamer.
I emailed them again and they said some stores should be able to order the unit so I might ring a few stores tomorrow and ask them. -
Cool, but for the record, the only time I have seen firmware be the culprit is if someone tried to do the update without being hardwired.Originally Posted by johns0
Additional filters - only if you want toOriginally Posted by mja
Proxy - not needed most of the time
cookies - only if you want to never save web information
java - can cause problems
Active X - can cause problems with Flash - do not recommendBelieving yourself to be secure only takes one cracker to dispel your belief. -
There was one cheapo router that needed firmware update cause it kept going offline,think it was a soho and all of them needed to be updated.
Is built in Vista firewall any good if not what recomended + parrallel port
By Rudyard in forum ComputerReplies: 20Last Post: 28th Jul 2008, 03:58 -
Comodo Firewall Pro - Free firewall
By bluemoss in forum ComputerReplies: 7Last Post: 10th Nov 2007, 10:44 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01 -
Which firewall for Vista 64
By mysts in forum ComputerReplies: 2Last Post: 5th Sep 2007, 22:34 -
Install McAffee Firewall and an Anti-Virus on Vista?
By Garibaldi in forum ComputerReplies: 2Last Post: 24th Jun 2007, 09:11
