  1. im creating a vcd that consist of 4 mpegs with a menu. Why does it stop after each mpeg when i preview it in TSCV. I want it to automatically continue to the next mpeg. I though the timeout variable sets this or do i need to set the paus eup when i burn.
    Any help appreciated.
  2. First, know that there will be a pause between each track. No matter what program you burn w/ there will always be a pause between tracks on a x(S)VCD. If you want to play the multiple MPEGs seamlessly then you need to merge them all together into one large MPEG, and make entry points (which act just like chapters) where desired.
    Second, I'm not sure I understand your question. Is it that the disc stops playing at the end of the each track, there's an infinite pause at the end of each track, or you return to your root menu/mpeg at the end of each track?
    Either way, you need to set the next selection to be the next track.
  3. Thanks you answered my question in that I have to burn one long mpeg and use chapters. i thought i would be able to link multiple mpegs up seamlessly.
  4. Actually i do have another question. I want to set it up so there is an intro, this is easy I can use the intro option in TSCV but how do I get my motion menu to come up instantly after the intro.
