Hihah
Just started using avisynth and virtualdub. I have downloaded all the filters from the avisynth website except for masktools, the first version. When i open my avs script in virtual dub i get a error message ... that it cant open the above file although its installed in the plugin directory. I found a script on the doom9 website which is the following :
Anyone might know what im doing wrong?BTW do you know where i can get the other version of masktools. I have downloaded both versions from the avisynth website but they seem both the same.Code:LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\HDRAGC.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\depan.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\mvtools.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\RemoveDirt.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\FluxSmooth.dll") #LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\MaskTools.dll") can't find this filter LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\mt_masktools.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\deblock.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\Deen.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\RemoveGrain.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\Repair.dll") #LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\MaskTools.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\VagueDenoiser.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\RemoveDirtS.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\RemoveDirtSSE2.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\FFT3dGPU.dll") LoadPlugin("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\fft3dfilter.dll") Import("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\SeeSaw.avs") Import("C:\Documents and Settings\riksnuiverink\Bureaublad\virtualdub\VirtualDub-1.8.6\plugins\RemoveNoiseMC.avs") QTInput("C:\Documents and Settings\riksnuiverink\Bureaublad\fantastic car.wmv") ConvertToYV12() Tweak(hue=0.0,sat=0.5,bright=0.0,cont=1.0) vlq_filter_ultimate() HDRAGC(avg_lum=-128,max_gain=3.0,min_gain=1.0,coef_gain=1.0,max_sat=9.0,min_sat=0.0,coef_sat=1.0,protect=2,passes=4,black_clip=0.0,shift=0,shift_u=0, shift_v=0,corrector=0.8,reducer=0.5,shadows=true,avg_window=25,response=100,debug=0,freezer=-1)
Keen to hear from you
regards,
Rik
How about a screen print of the error message?
Buy My Books -
http://forum.doom9.org/showthread.php?t=89941
To use this filter you need directx 9.0c or better and a graphics card supporting directx 9 in hardware. That is at least an ATI Radeon 95xx or Nvidia Geforce fx 5xxx. -
Jagabo....thanks i should have read the whole thread instead of just sections of it. You are right. Dont think my computer will support this filter since i dont have that kind of graphic card. Going to try it anyways...Originally Posted by jagabo
Do you know if there is a filter that is similar to fft3dGPU?
Dll Filters for avisynth 2.5 sometimes working, sometimes not
By kaskaļ in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2011, 12:32 -
AviSynth open failure in VirtualDub
By fatcharlie in forum Newbie / General discussionsReplies: 5Last Post: 3rd Mar 2011, 21:32 -
AviSynth open failure:
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 29th Jul 2008, 20:35 -
Avisynth open failure for cropping
By php111 in forum Newbie / General discussionsReplies: 51Last Post: 26th Mar 2008, 12:24 -
AVIsynth failure in VD
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2008, 04:08
