Hi,
We see the animated title in sevarel movie as .VOB format. But, I want to add the same animated title while creating the same movie using GFD.
There is a option in of animation in GFD, but I don't know how to use.
Can any one explain me/is there any tutorial to add (don't want to create newly) animation in GFD collected from dvd with the same options like - Play/chapters...?
~r
Results 1 to 11 of 11
There is only a (very old
) guide here:
http://download.videohelp.com/gfd/Motionmenu_eng.html
But actually I don't understand your question...GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I don't really use animated buttons or menu backgrounds myself. I only tried it as an experiment, so I can't be of much help to you.
There is a lot of detailed guidance, broken down by topics at http://download.videohelp.com/gfd/GUI_DVDauthor_eng_07.htm
In addition to borax's link, you might find the help you need at the following links from that page:
http://download.videohelp.com/gfd/Help/ShortdescAnimMenus.html or http://download.videohelp.com/gfd/Help/MenuBackgroundDialog.html -
I dont want to create my own, just use the existing animated menu of a the similar movie, is it possible in GFD?
And sorry for not to make clear my question...Let's describe below:
After start a dvd movie in TV/pc, the main manue appears in the display screen. From there, we select play/chapters, etc... in main menu, there may be a still image or animated pictures of that movie. In animated menu, slowly the play/chapters button appears, sometimes there may be music also...clear?
But now, I m just adding still image of a movie with GFD.
How can I do that? -
Hi Guns1,
Thats right, motion menus. but u only believe!!! No alternate soft can do this? I dont want to waste time to create new motion menue.
Now I m convrting total .VOB files of movie ro 1 mpeg files with vob2mpg, then importing in GFD & create dvd with a static image.
If u work on it, then plz guide me, how can it possible?
Or is there any tutorial on it?
~r -
...clear?
No. Please describe it in more detail what you want.
...I dont want to waste time to create new motion menue.
Most times it is more work to analyze an existing menu to adapt/reuse it for an own movie than creating a new one...GUI for dvdauthor:
Hi All,
I can't undertand why u "borax" not clear about what i want!!!
->Most times it is more work to analyze an existing menu to adapt/reuse it for an own movie than creating a new one...Exactly I want to reuse a motion menu from existing dvd movie. but problem is how can I import, put buttons...etc?
Guns1,
->Once you have extract them you can load them into GFD as backgrounds, but you will have to define your own button areas and link them to your own assets...ok no problem, I'll define myself. but how can I extract them(using which soft) & import as background & tell me which soft u use to that with tutorial.
~r -
I agree with borax. Adapting an existing motion menu for use with a different movie won't save you any work. It will more likely make for more work, and you may not be happy with the end product.
If you still want to pursue your original goal, all I can do is give you some suggestions that might help. Like I said, I don't use motion menus for my projects.
Do you want to re-use the menu without changing it at all? If so, you may be able to use a different approach and replace the movie. There is some information about that in this thread: https://forum.videohelp.com/topic351654.html
If you still want to use GFD or customize the menu, here are some hints:
The sequence where the buttons slowly appear may not actually be part of the menu. It could be a video that plays before the menu is displayed. (Like the "Intro Movie" section under the "Project" tab in the GFD "Default Settings" dialog window.) If so, you will have to look someplace other than VIDEO_TS.VOB to find it. You won't be able to customize an "Into Movie" using GFD, though you might be able to make it into a motion menu that could be customized.
Once you find out where the animation really is, extract the video. Try using a demultiplexer for that. It separates a VOB into its elementary audio and video files. You can then import those into GFD as motion menu assets or "Intro Movie" assets. I use Rejig and VOBEdit most of the time, but there are more good, free demultiplexers in the VideoHelp tools section.
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
MKV with SRT subs, create title menu, burn to BD-R for standalone player
By Delta007bhd in forum Blu-ray RippingReplies: 3Last Post: 9th Mar 2011, 19:32 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Wax 3D animated title creation result jerky video
By SearchQuality in forum SubtitleReplies: 0Last Post: 24th May 2008, 16:37 -
What software to create a multi-title menu?
By ChrisPappas in forum Authoring (DVD)Replies: 1Last Post: 26th Nov 2007, 02:28
