Hello guys I have a couple of pal dvd's that I am wanting to change to ntsc format and I know about region free dvd players etc but I only have a few dvd's to do and it does not warrent me to get one. Ok I have some dvd's that are around 7.2 gb and would I get better quality if I rencode it to 4.3gb ntsc format then put on dvd or would I get better quality recoding it to 7.2 gb ntsc then shrink with dvd fab platinum? Which route would give me the better results? What I am using to encode is Tmpeg 4.3 xpress. Thanks for any help or suggestions.
Eric
I would re-encode it to ntsc once... shrinking it during the re-encode to fit on a single layer disc. Multiple encodes will degrade quality... best to do it only once.
Even a broken clock is right twice a day. -
That is what I was thinking that encoding it once then transcoding it would degrade it too much. Thanks
You have to manually re-encode to get from PAL to NTSC so just make sure you use a bitrate calculator and use a bitrate during the re-encode that will allow the content to fit on a single layer DVD disc.
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 17:52 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 11:33 -
how can i convert my dvd5 to dvd9
By scratchlikeme in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 21:54 -
How to shrink DVD9 to DVD5 with no Quality loss?
By CERO in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2008, 07:18 -
DVD9 To DVD5
By taylor6698 in forum DVD RippingReplies: 3Last Post: 22nd Oct 2007, 21:36
