I have a file which was recorded as 16:9 but the "real" video is only 4:3
I want to remove the black areas on the sides of the 16:9 and save the file as a 4:3
I need a simple, quick way to do this
I have looked at Virtualdub but am not sure exactly what to do out of the myriad of options?
Any help would be appreciated
TopCat
What format do you want the final video in ?
Cropping in vdub is easy. Open the Filters screen and add the Null Transform filter. This does nothing to the image, but you can now click on the crop button and visually remove the pillarboxing. Once you have finished cropping, add a resize filter and resize to 640 x 480 and see how it looks. If it is OK, set your compression settings and save the new video.Read my blog here.
thanks for your reply
what I am trying to do is combine two video clips into a single title on a DVD - I am using Nerovision 5 to do this
the first clip is a standard 4:3 - the second one is also 4:3 but came from a widescreen 16:9 transmission
when I put them into a Nero title the first one looks fine but the second one has black bars on all sides even though it is really 4:3
I will have a go at cropping and resizing as you suggest
thanks again
how to remove noise from my recorded videos
By harmeetmatta in forum Capturing and VCRReplies: 18Last Post: 6th Apr 2010, 07:45 -
Old VHS Tapes Have No Picture Recorded at LP and SLP Speed
By Hypnotised16 in forum MediaReplies: 14Last Post: 17th Mar 2010, 16:09 -
Putting a black frame on left side only?
By gonzo90017 in forum EditingReplies: 5Last Post: 24th Dec 2008, 14:28 -
PPCS3 Exporting to 'Movie', Side Black Bar Problems
By joepurple in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2008, 19:15 -
HTPC (Black side and top bars)
By donigodinho in forum Media Center PC / MediaCentersReplies: 2Last Post: 12th Jan 2008, 09:24
